Here is a workaround for how to copy a Sketch to a new offset plane, hope this helps 🙂
http://autode.sk/1xxoDCK (screencast)
1. Make a Sketch
2. Stop Sketch
3. Create Offset plane from Sketch + start new Sketch
4. Stop Sketch
5. Go back to first Sketch and edit then select all with mouse and click "ctrl + c"
6. Stop Sketch
7. Go to second empty Sketch you created previously
8. Edit this empty Sketch
9. Do ctrl + v
10. Done 🙂
Of Course it would be helpfull if the dev team could implement a shorter way (for example just ctrl and drag to new offset plane like in my suggestion here http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/copie-sketches-with-ctrl-drag-to-new-...
but hence it works this way too 😉
Cheers, Hans
