Announcements
How to control curved wood grain direction
MrtnST
MrtnST
I would like to be able to control wood direction on a curved body to make it look like steam bent wood. Texture map control doesn't give me the option to make the grain direction follow a path really.  Is there a way to achieve this in any way?
Replies (18)
Beyondforce
Hey @MrtnST ,
Are you using a 3D texture or a normal texture?
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Fusion 360 Hardware Benchmark: TESREG.com
Visit us on Facebook Page Facebook community
YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
MrtnST
Hey @Beyondforce
Thanks for your reply, I am using 3D-texture but I realize now when testing "normal" texture this would solve my problem. However normal texture is very limited to just a few different kinds of wood and finishes. Is it possible to get the same options and quality as 3D-texture wood to the normal texture wood?
Beyondforce
Have you tried to play with the 3D texture settings? You can change direction, size etc.
Ben Korez
Facebook | YouTube
MrtnST
Yes for sure, but there is no option for this since it is a 3D-wood and it represents a plank or a piece of timber which naturally would be straight and not bent.
Beyondforce
When using the 3D texture, you can still use the "Texture Map Control" which should help you get when you need.
Ben Korez
Facebook | YouTube
MrtnST
Thanks for your help but unfortunately not, or at least I can't get the grain to be following the direction of the body when using 3D texture and map control. Can you explain in detail how you would do it?
Beyondforce
If you could attach a picture with the exact end result, then I'll make something for you.
Ben Korez
Facebook | YouTube
MrtnST
Sure just see my attached image on the original post. There you can clearly see the problem with the grain. If I go to texture map control I can't use any tool to create what I want besides rotate the direction of the grain 360degrees.
Beyondforce
Maybe @TrippyLighting can help? He is really good with textures.
Ben Korez
Facebook | YouTube
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here?
My guess, and this is just a guess, is that you will have to Split the face (turn off edge display) and individually manipulate appearance on different faces.
TrippyLighting
@Beyondforce thanks for the mention.
@MrtnST I am assuming that the rail for this chair would be steam bent. Texturing this properly usually requires UV mapping and Fusion 360 does not offer you the control to do that properly.
For plywood this can be made work as demonstrated starting with message 54 in this thread, but for sculpted or round structures that probably does not work.
MrtnST
Thank you @TheCADWhisperer
Please check my attached file
/Martin
TrippyLighting
I have to correct myself!
If you use one of the non 3D wood textures, when applied the grain follows the direction of the bend. At least it does on this circular bend. If you need other textures I can recommend these from Arroway.
MrtnST
Yes correct, too bad there is such few options of non 3d textures. Seems like I must buy addiotional textures for this to work.
Thanks everyone
MrtnST
Thank you!
Great tutorial on how to add new textures for sure. It did not solve my issue unless I purchase new textures and invest time in adding them into Fusion and work with non 3d textures i guess.
TrippyLighting
Why would that not solve your issue ?
MrtnST
Sorry, you are right, it probably did solve my issue. However, I thought it would be a solution within Fusion to make this rather than buying new texture and apply them. Correct me if I am wrong but there is no free quality wooden texture to be found right?
TrippyLighting
I came across the Arroway textures 7-8 years ago and at that time "free" and "high-quality" as it pertains to textures were mutually exclusive. That might be different now as people are using different methods of raising money such as Patreon.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
