HOW TO CONNECT LOTS OF SMALL LINE SEGMENTS OF A DXF FILE
daveaburnham
Message 1 of 12
daveaburnham
so i uploaded a dxf file and the lines look like there connected but are actually a bunch of small line segments with no spaces between them. is there a way to connect them all together fast?
Accepted solutions (3)
Replies (11)
Message 2 of 12
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 3 of 12
daveaburnham
i hope i attached it right
Message 4 of 12
etfrench
The Divide and Conquer method works well for finding the broken boundary points.  If you want to replace all of the line segments, then you'll need to manually create splines to fit.
ETFrench
Message 5 of 12
rushabhthakkar_910
Simple and faster Add-In... "ConnectTheDots"...
See this Youtube Video... https://youtu.be/3cKq5V2Gtdc
Link to the Add-In...  THIS  (Also shared in the Video Description)..
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 6 of 12
etfrench
Did it actually work on this file?
ETFrench
Message 7 of 12
rushabhthakkar_910
I have not added this Add-in yet... Because the response of Fusion is not very good.. So, I am currently not adding any Add-ins...
I just saw the video, and thought of sharing it...
Thanks and Regards,
Rushabh Thakkar.
Message 8 of 12
etfrench
I've found that it's a good practice to actually try a solution before recommending it.  It's easy to miss some of the nuances of a problem.  Sadly, I must admit to missing many 😁
ETFrench
Message 9 of 12
rushabhthakkar_910
Yes Sir, I agree... (Maybe Shifting from the Topic), But I don't want to overload Fusion. As such I am very frustrated with it's working..
Thanks and Regards,
Rushabh Thakkar.
Message 10 of 12
g-andresen
here are cleaned files f3d and DXF
I removed duplicate vectors and converted the contours to Bezier with a tolerance of 0.001 mm.
This way the size of the file is dramatically reduced.
günther
Message 11 of 12
etfrench
Good catch.  I should add hovering over the problem spots while depressing the left mouse button (Windows) to the Divide and Conquer method.  Removing the duplicates resolves the problem(s).  How did you do the deletions and conversion to Bezier?
Another failure mode is having Z axis offsets in the dxf file.  This can be found be selecting the geometry and checking the context menu for a menu item to move sketch items to the sketch plane.
ETFrench
Message 12 of 12
g-andresen
V-Carve pro
günther
