how to combine two angled bodies?
ihttkc
Message 1 of 15
ihttkc
hello all, i drew two separate shelled bodies angled towards each other and touching at an outer edge. i would like to find out how i can combine these two bodies by filling up the wedge of space between them?
Replies (14)
Message 2 of 15
JHRendon
You should use "combine" tool. Those two bodies should have more contact between them.
So one option is extrude an sketch and make other features to join them in a way you want. Like this:
Message 3 of 15
etfrench
I would suggest using the Loft command between the bottom of the top and the top of the bottom.  A plain Loft will be straight between the two faces.  If you want it curved, then you'll need to use a rail.
p.s. Attaching your file to the thread will get you more precise answers (File/Export/Archive file *.f3d).
ETFrench
Message 4 of 15
ihttkc
thank you for taking the time to response. i have tried a revolved extrude from one surface to the other. it works.
Message 5 of 15
JHRendon
Revolve would work and you can set the angle or loft (creating the sketches).
Message 6 of 15
shahriarsifat1802164
You can easily use the combine tool to combine multiple bodies.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 7 of 15
The thing is do you want to make a straightforward loft?
RUET
Thank you.
Message 8 of 15
Can you please share your model?
Thank you.
RUET
Thank you.
Message 9 of 15
RUET
Thank you.
Message 10 of 15
When I combine those bodes it turns into a Screenshot 2021-02-05 150753.jpgsingle body.
RUET
Thank you.
Message 11 of 15
RUET
Thank you.
Message 12 of 15
I am providing a screencast please have patience.
Thank you.
RUET
Thank you.
Message 13 of 15
Loft as a new body | Fusion 360 | Autodesk Knowledge Network
Here is a screencast.
RUET
Thank you.
Message 14 of 15
I think it will work.
Thank you.
RUET
Thank you.
Message 15 of 15
ihttkc
thank you for all replies and suggestions. attached is my revolve extrude solution (i discovered it by chance).
