How to change the revolute joint snap point when using "Between Two Faces"?
robert_roosL5G95
Observer Observer
robert_roosL5G95
Observer
Observer
I have an assembly where a door is fit in a frame. There is a small margin, so no faces are touching directly. I can joint the door in place easily with the "Between Two Faces" selection: the door is now centered between the left and right door post, and aligned at the bottom.
But I want the door to pivot of course. And if I change the joint I just made to "Revolute", it will rotate around the middle of the door (the snap position I made with the selection tool).
How can I still center the door, but have it rotate around a different point?
jhackney1972
Please attach your model.  Open in Fusion, select the File menu then Export and save to your hard drive.  Attach the file to a reply post.  If your file is a F3Z file you may have to Zip it first.
John Hackney, Retired
robert_roosL5G95
Observer
Observer
My bad, I thought the situation was basic enough.
This is a small part in a larger model I don't want to share yet, but I made a demo that still shows exactly this problem. I updated the original post: download link.
Note that in my demo this could be avoided with an "As-Built Joint", but in my real case it's a linked component instead, so it's not an option.
Thanks!
g-andresen
watch screencast and ckeck joint setting
(view in My Videos)
günther
robert_roosL5G95
Observer
Observer
Thank you for this very clear video! Indeed, using an offset in the joint is one solution. And using parameters would save me from having to define a dimension twice (as a derived dimension).
I'm guessing there's no way to separate the revolution axis from the "Between Two Faces" selection option then?
g-andresen
Between 2 surfaces makes no sense here.
Günther
