Message 1 of 37
How to change the position of a Primitive ( Box, Cylinder, coil, etc... )
I am having difficulties to find how to move a Primitive ( Box, cylinder, Coil, etc...)
When you create a sketch you setup dimensions, however I can't find how to create dimensions to position the center of a sphere or other primitives.
typical case, if I create a hole made with a sketch and want to have a coil inside it, I can't modify the position of the hole sketch and have the inner coil to follow. I am very puzzled by the use case of these primitives if they can't be constrained to positions.
Thanks for your hints and input,
Bye,
Jean
