How to change dimension orientation?
This has to be very simple, but I can't find an answer, at least one I understand.
Some of my dimension text is on one side of the line while others are on the other side. I thought it might be the order I was picking the objects, but that didn't seem to help.
jhackney1972
The location of the model sketch dimension is dependent on the sketch point order you select.  See Screencast (no sound)
John Hackney, Retired
chrisplyler
Also, unless you're just OCD about the visual of it, it doesn't matter one way or the other. Your SKETCH dimensions aren't going to show up when you make an actual DRAWING.
