How To Chamfer a Nut
alan
Message 1 of 8
alan
I have been struggling with this for a while.  We design parts with hex ends for like screws.  How do you add a chamfer or draft or extrude what ever it takes to get the desing done.  The chamfer I am interested in looks like this;
Thanks for helping.
Replies (7)
Message 2 of 8
TheCADWhisperer
Extruded-angle Intersection circle
or
Revolve cut triangle.
Message 3 of 8
Hello @alan
I don't know how to do it by chamfer command but you can get the same result by drawing sphere contains your model and cut the outer edges .
Message 4 of 8
jeff_strater
I like @Anonymous's sphere approach.  Very clever.  The result is a spherical surface, which might be perfect.  If you want a conical surface, use revolve:
Jeff
Jeff Strater
Engineering Director
Message 5 of 8
TheCADWhisperer
See attached for simple circle-cone technique.
Message 6 of 8
alan
Thanks to all that replied.  All the methods work.  I was hoping for something simple but there does not appear to be a select and done procedure.  After trying each method I am going to use this in the future.  Ussually I draw hex then extrude.  Now I am going to draw cylinder, chamfer, then draw hex and cut.
Thanks agian for eveyone that took the time to help.
Message 7 of 8
TheCADWhisperer
This does not sound right to me?
Edit:
I guess that does work. Although the chamfer would have to be calculated to get tangent and would be a bit more difficult for 30° or 60° rather than 45°.
Message 8 of 8
zacwilliamva
Community Visitor
Community Visitor
Your own method is fantastic!
Thank you very much for asking the question and then updating it with your own solution because I think your solution is far better than others provided.Screenshot 2023-05-29 at 3.53.29 PM.png
