How to bridge gap in surface body
Hi there,
I've converted a quad mesh to T-Spline then to B-Rep.
When I attempted to convert from T-Spline to B-Rep I had some self-intersecting geometry so I deleted the faces that were causing the problem.
Now in my surface body I have a gap - picture below.  I would like to bridge this gap.
Can anyone suggest the best way to do this?  Don't mind whether this is in the Form workspace or Surface workspace.
Max
TheCADWhisperer
Attached now.  I've cut everything off the model that isn't in the region of the problem area.
Max
mango.freund
hello @Anonymous  take a look -- greatings mango
https://www.youtube.com/watch?v=RDvrRXfpzSQ&t=1674s
TrippyLighting
Please share the original design including the timeline and T-Spline body.
Also share what it is you want to design.
Mixing T-Splines with other modeling tools can be done but goes along with a number of caveats you usually don't find discussed on YouTube.
Thanks @mango.freund
This video really helped!  By unstitching, extending, trimming etc I was able to make a solid body which was the ultimate aim.
