How to break link btw rectangular pattern components?
kris.chlapek
kris.chlapek
Good Morning,
As per topic,  how can i break link btw the components that where created using rectangular patter (or any pattern) so that each component could be modified individually if needed?
Thank you
g-andresen
1. create pattern with bodies
2. create components from patterned bodies
Screencast
günther
jhackney1972
In the Screencast I  show you how I would do what you desire.  Two things to note, one the Boundary Fill Component will lack an included sketch, it will use the one used to create the original component used in the pattern, two if you suppress the pattern component rather than just turn of its visibility, you will get a "yellow" error background on the Boundary Fill operation in the timeline.  In my opinion this can be ignored and will disappear if you un-suppress the pattern  component instance.
John Hackney, Retired
shahriarsifat1802164
Make them independent components will work here.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
jhackney1972
I agree but this method assumes your are using Direct Modeling or you are not opposed to doing away with your timeline of an in-process model.  I for one think this is not desirable but that is the designers call.
