how to automatically calculate angle parametric design
I have a question, I am working on a parametric design.
I need to draw a coil that is at a angle, but the angle is not always the same.
for example,
i have a body with these dimensions:
Top:80
Bottom:70
height:90
I need to draw a coil at a angle, that angle needs to be the same as the side of the cylinder.
the angle in this example needs to be: 3.17983 deg
but it has to calculate it automatically, how do i do this?
HughesTooling
Create a parameter using this formula atan(( CylinderTop - CylinderBottom ) / 2 / CylinderLength)
Make sure the unit type is Degrees.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks! it works, but i have one question, the value is 3,2deg but the exact value is 3.17983 deg is it possible to get a more exact value
HughesTooling
Go to your preferences and under Angular Precision change to more places on the Unit and Value page. Not sure but I think the system uses more places than's displayed.
Mark
Mark Hughes
