Message 1 of 13
Working with some organic looking geodesic domes and I am looking to put windows in most of the faces of the solid object.
I have found a good workflow where I make a sketch, give it an offset, then extrude through to make a window... But it is taking a long time and there are many windows...
By taking a look at the screencast is it possible to automate this or make it go any quicker?
For instance, can I select a bunch of faces at once and perform the same operation on them? Just looking for a way to make this easier and quicker to do!
Thank you for any tips! First Screencast so I hope I did an okay job and attached it right... Cheers!
