How to apply loads and constraints in Generative Design (the same faces cannot be selected as in static analysis)
harolis_susanade
Message 1 of 1
harolis_susanade
Hello everyone, I am having the following problem, and I would be very grateful to receive your answers.
So, after finishing editing the model and defining the zones to preserve and the obstacles when I wanted to apply the remote load and constraints in the same way as I did in the static analysis it was not possible for me to select the same faces.
I even created a new body (from the upper ring), but it only let me select the edges and not the face as illustrated in the following picture of the static analysis.
Constraints setup (static analysis) below:
I also want to apply the same configuration of the remote loads of the static analysis in the Generative Design. This is how I set it up for the static analysis.
Thank you very much
Harolis
**The file is attached
Replies (0)
