Hi All,
I'm building a clock and am having a very difficult time creating motion that respects the gear ratios. I have extracted the hour and minute hand portion of the clock as seen in the photo below. The red items represent the minutes and the arbor poking out behind the frame will be driven such that the minute hand completes a 360 degree rotation every hour (naturally!). The blue parts represent the hour hand and must rotate 360/12 = 30 degrees when the minute hand rotates 360 degrees. The yellow and green gears in the actual clock implement the 12x stepdown for the hour hand (the blue parts are free to rotate on the red parts).
My attached project attempts to do this by creating three motion links.
1. Red gear to red arbor - 360 deg to 360 deg
2. Red gear (20 teeth) to yellow gear (60 teeth) - 360/20 deg to 360/60 deg
3. Green gear (16 teeth) to blue gear (64 teeth) - 360/16 deg to 360/64 deg
If you look at the attached project you'll see that the motion is bizzare and bears no resemblance to what I'm trying to do. Any help would be greatly appreciated.
Oops! The forum is telling me the project is too large to upload. How can I share it with you?
Ken
