Message 1 of 25
Hi
I want to align a vertical plate 10mm thick on an angle on another flat plate.
The angle the plate needs to align on is off the xy axis.
The align tool seems to only allow centering on the straight.
It would be handy for my project if I could align a base surface at two points, like the two edges of the vertical plate to two location points on the horizontal plate.
Or as you can see here, the two holes in the vertical plate with the holes in the horizontal plate.
I just cannot work out how to do this.
Kind Regards
Ian
