How to add "teeth"feature
How do I add gripping, or "teeth" features to the flat surfaces on the jaws of a tool that is similar to a pair of pliers? They need to run perpendicular to the length of the jaw, be spaced about 1/16" apart with a depth of 1/32", and have a slight rearward angle. They would be very similar to the gripping ridges on the jaws of a pair of pliers. Thanks for any help.
HughesTooling
Here's a short screencast.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Didn't read carefully enough, to make the tooth steeper on one side just add an angle dimension instead of the midpoint constraint.
Mark
Mark Hughes
Thanks so much. I'm new to Fusion and haven't worked in any CAD software for
20 years, so basically, a complete newbie.
Bob Rockwood
540-422-9117
HughesTooling
Hi Bob
If you're learning Fusion these links might be helpful.
Sketch exercises.
Model exercises.
Mark
Mark Hughes
