Hi
Im running nuts right now. Originaly im from Oneshape.
So i have following Situation.
1 - I open a file (Frame) I design a Frame which will change dimensions later in the design process.
2 - I made a new file (Assembly) and "insert into current design" the frame as component
3 - Now i need cover-plates that match the frame, so i need to design them on the (frame) file.
4 - Now i would like to put ONLY the plate into the assembly file (remember the dimensions will change)
5 - I want the whole design parametric as well the plates so exporting a component isnt the solution.
6 - I dont want to add 100 sketches to my assembly file.
Is it possible to add a single component from a Construction to a file for assembling?
In Onshape this is a nobrainer but Fusion makes me Confusion?
Thanks for any help!
