How to add decimal places into drawing dims
Hi
I've been looking for this in here but didn't find any answers for such a silly question. All I need is to add decimal places and let fusion add it for me automatically based on my default setting. Then adjust it manually by choosing different option. Once again easy to do in inventor but seems impossible in here. My target is to add tolerance chart into a drawing based on dims annotation decimal places
1 decimal place +- 0.2mm
2 decimal places +- 0.1mm
3 decimal places +-0.05mm
So if I got dim 10.0 then tolerance is +- 0.2mm if it is 10.00 tolerance will be +-0.1mm
So far I can not add any decimal place into the dims annotation. Is it even possible or do I have to manually add it there on each annotation?
HughesTooling
If you double click a dimension the dialog shows Primary Precision the changes decimal places for that dimension.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Sorry your image wouldn't show the first time I clicked it, best to paste images into the text.
From the browser Display Trialling Zeros.
Mark Hughes
Sorry but that doesn't add decimal places into round number... you can Changi it to whatever precision you want but if the dim is 10 it always will be 10
ohh.. yes.. that helped.. thanks.. BTW I've been trying to fix that image but not even pasting didn't work... format is unsupported even though it is normal png image
HughesTooling
Did you see my second message about the setting in the browser? There's no setting for individual dimensions, so you need to set the display trailing zeros to yes then adjust decimal places in all dimensions.
Mark
Mark Hughes
yes... the second reply came late... all sorted now... thanks
