How to add a wall to a complex form?
romqaivanov
Observer Observer
romqaivanov
Observer
Observer
I am new to apps like Fusion 360 and I got stuck with wall that closes the body.
I am trying to add a wall that follows specific shape and closes the existing frame organically but can't finish it.
It is a part of a sewing machine and originally it has a squared bottom, but I want to create a new one with a cropped edge, so it is easier to work with specific items.
I tried different kinds of extrusion but it doesn't work as I want to.
jhackney1972
Is this what you are wanting?  Your sketch has a wavy line in it but I used it as is.  Model is attached.
John Hackney, Retired
etfrench
Like this?
ETFrench
SaeedHamza
Could you please attach an image similar to the final result you're trying to achieve, the desciption alone isn't sufficient.
Saeed Hamza
romqaivanov
Observer
Observer
Thank you very much! That is almost what I needed, except that new wall has to be 3mm thick, so I extruded it in with 3mm offset and now it works.
I checked the steps you made and now have much better understanding on how that works! Thank you!
romqaivanov
Observer
Observer
Thank you for reply! The solution has been posted above, but thank you for your effort!
romqaivanov
Observer
Observer
Thank you for reply! The solution has been posted above, but thank you for your attention!
