How do you rotate a component?
So I know you can drag your components around without adding a move to the history bar, but how do you rotate them?
jeff_strater
Use Move to do the rotate, but set your filter ("Object") to "Components"
Any component transformation (drag or Move) does not go into the timeline.  Only if the Move Object is a Body or Sketch does it create a Move feature in the timeline.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Thanks Jeff!
