How do you render Textures like Pillowcase, cloth, couch, sofa, blanket? PLEASE
Could someone show how you would wrap an item with cloth?
what it the workflow for do this?  please.  it has a curved surface so it makes it seem even trickier.  thank you so much for any advise
Attached is a file of a memory foam pillow.   I want to wrap a nice pillow case on it using Fusion 360.
Could someone please tell me or upload a tutorial of how to BEST go out about wrapping this in a nice pillowcase.
How do you start?  Click Sculpt and Try to make a FACE? or a BOX?  how do the pros do it?
Thank you guys.
innovatenate
Autodesk Support
Autodesk Support
There are probably better ways to accomplish this, but I took a swing and recorded it. See the links below.
Design:
http://a360.co/2eGFjt7
Screencast:
http://autode.sk/2ghsbuP
If you haven't gone through the tutorials for the sculpt environment, you may consider starting with those before diving into the deep end.
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-FD18808F-74B1-4E30-9358-61CF6E3FAAB6
There's also lots of great content on youtube and this forum about the sculpt environment to check out.
https://www.youtube.com/playlist?list=PLmA_xUT-8UlLfPIsxMZWGx50lQht4bJqh
https://www.youtube.com/playlist?list=PLmA_xUT-8UlJMlVUue32aqjt2g-dYfW0_
Our Learning Partners may also have some helpful content.
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-27D089C0-5FC5-4AD4-841F-6E983AC99DCF
I hope this will help to get you started! Let me know if you have any questions.
Nathan Chandler
Principal Specialist
