How do you make this type of pattern?
hungddngo
hungddngo
I am trying to make these triangle look pattern inside the sketch, just wondering how would I be able to go about doing that?
laughingcreek
If this will eventually be 3d geometry (which I assume is the case)  you don't want to create all the triangles in a sketch.  Instead sketch one triangle element, extrude it, and pattern the body.
hungddngo
what pattern option would I use to pattern it on the body?
hungddngo
This would be 3d printed, I wanted a cool pattern.
etfrench
Here's one way to create the pattern:
Notes:
You could also use a pattern to create the horizontal lines.
You will also need to convert the lines into a 3d model.  In other words, the lines aren't going to print as they are.
Have you looked at the infill patterns available in your slicer?
ETFrench
laughingcreek
another approach
hungddngo
Thank you!
