How do I undo Create Group in the feature tree
Message 1 of 8
After I create a group, there's no way to undo it, or rather, to ungroup. Worse, there's no way to move a more-forward feature/sketch/body into a group that's been created. Am I not supposed to use the Create Group feature?
Replies (7)
Message 2 of 8
Nevermind, figured it out. It's unintuitive, IMO.
Right click on the group, and click Delete
then delete just the group and expand its contents
It's not obvious that there are options after "Delete." It's not something someone would naturally press.
Recommendation: Create new button that says "Ungroup" or change menu title to "Delete..."
Either way, when I have a group, I should be able to move a feature to inside a group, rather than, delete entire group, move feature, create group. That's 6 clicks when it should be 1.
Message 3 of 8
ImpliedPlot712
Observer
Observer
Thanks for this. I definitely wouldn't have tried deleting the group to "ungroup", that is not intuitive to me. Seems like most programs with a group function also have an ungroup.
Message 4 of 8
guillaumepml
Community Visitor
Community Visitor
Thanks for the solution to ungroup.
But I don't succeed to move a function or sketch into a group already created, or from a group into another one, even if is not due to moving the sketch before a link for example a projection.
So to do that I "ungroup" the 2 group, move my sketch and then recreate the group.
Is there a better way?
Thank in advance for your help
Message 5 of 8
jeff_strater
unfortunately, no, today there is no better way to "edit" a timeline group.  I'd like to have a better way, myself.
Jeff Strater
Engineering Director
Message 6 of 8
ritste20
@jeff_strater
Any update on expanded functionality of the group command? I recently started using this to clean up a fairly lengthy timeline and it would be super helpful if I could drag new features into a previously created group without deleting and trying to capture all the associated features again in one shot.
I also agree that delete probably isn't the best name for the "ungroup" command. Maybe something more along the lines of "dissolve group" or "manage group" with an additional options menu.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 7 of 8
jeff_strater
no change yet, unfortunately.  Still on the large "to do" list...
Jeff Strater
Message 8 of 8
DanielZhuk
Hi @Anonymous . Thanks for the solution, I was looking for this as well. Very untuitive indeed.
Just an 'Ungroup' button would be great, maybe? @Fusion team.
Also being able to group inside of a group could be nice too, wouldn't it?
