How do I move a folder in the data panel or A360
TrippyLighting
Consultant Consultant
Message 1 of 15
TrippyLighting
I am trying to move. folder with some designs into another folder within the same project.
How do I do this ?
Replies (14)
Message 2 of 15
PhilProcarioJr
@TrippyLighting
Houston, we have a problem!!
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 15
TrippyLighting
Well.. the filter shown in this quick tip also only works on files, but not on folders.
I am at a loss of words! Well...not really, but I do need to adhere to the forum rules ...
via GIPHY
Message 4 of 15
PhilProcarioJr
@TrippyLighting
All I can say is add it to the ongoing list...........
Phil Procario Jr.
Message 5 of 15
TrippyLighting
I mean, come on ..... really ?
That same quick tip also shows that when you click on one of these little arrows you get a panel that presents you with the other folders at the same level.
However, when that list is too long it just gets cut off and there's no scroll bar allowing you to get to the folders further down the list.
I've been able to do this stuff 30 years ago with Norton Commander in DOS!
Message 6 of 15
rumpelstielz
yep, one of my major gripes with the whole cloud based file management. i recently tried to organize all my fusion files and gave up after half an hour. i could live with the fact of not being able to move folders if at least i could get a decent list of all my files and sort them like i could in Win95. i can search for .f3d files but guess what, not all my files show up in the results and those who do show no modification dates and no way to sort. The returned list shows a creation date for each file but it's not sorted chronologicaly and there are no columns to sort by any other criteria as well.
makes ya kinda feel like the guy on the right here
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
Message 7 of 15
TrippyLighting
It appears that in a team hub, moving a folder is actually possible and very easy to do as I've confirmed with a client.
A team hub costs $120 annually for the owner of the  hub and each user that wants to work in a team hub also has to have a running subscription for $120 annually.
A fool who comes to the conclusion that availability of this "advanced" feature is kept to the team hub on purpose.
Message 8 of 15
banzledin
I believe that folders can be moved in
https://myhub.autodesk360.com/g/all_projects
To move to a new project folder, the new folder needs to be created before moving and a copy needs to be created in the project folder. Then the original can be deleted.
Message 9 of 15
TrippyLighting
@banzledin Yes, that can of course be done, but that does not really move a folder along with all the files in it.
Message 10 of 15
banzledin
Are you sure? I just tested it, see attached screenshots.
Move folder.Move folder.Select destination project or folder.Select destination project or folder.
Message 11 of 15
TrippyLighting
When I started this thread in 2017 this did not work.
I am glad to see that my posts here and on the Autodesk Expert Elite forum have resulted in implemented functionality you are going to be able to enjoy now.
Message 12 of 15
srgntballistic
This actually doesn't seem to do anything for me...
Always says "Cannot move selected folder."1122334455
Message 13 of 15
rumpelstielz
not working here neither, always getting "cannot move selected folder". as always a more explicit error message would certainly be helpful ...
tried once again to make some order in my files/projects but gave up again ... ordering projects/designs/files after the fact seems to be next to impossible.
Message 14 of 15
mavigogun
@TrippyLighting
We need a no-manual emoticon:   Project To Curved Surface  Demo v13 hr.png
Message 15 of 15
Perfect!
