How do I make notes on my skectch?
noah.s.coleman
Message 1 of 8
noah.s.coleman
I cannot find any documentation on how to make design notes to myself while in a design.  I understand that you can do this with the Annotate menu in the Drawing space, but how can I make in process notes to myself while in the sketch.  Let's say I'm not sure what a dimension should be, so I make a note that I need to check it.  I'm not looking to make text objects like with the text tool, just notes to myself that are not a part of the design.
Replies (7)
Message 2 of 8
TMC.Engineering
Try this
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Message 3 of 8
noah.s.coleman
Thanks, Timm!  That works for most of the use cases I can think of.  I do wish I could choose points on the sketch, rather than just on bodies or components, but the comments box should help a lot.
Message 4 of 8
Is there any way to create text directly on a sketch? Being able to edit,move, turn off/on etc as well?
Assuming the answer is no, can this be given consideration?
Message 5 of 8
jeff_strater
You can create text in a sketch.  There is a text command in sketch.  You can't, however, individually control the visibility of a text item.  You can move it around, resize, and edit it:
Jeff
Jeff Strater
Engineering Director
Message 6 of 8
Oh, I did see that but thought it was just for creating text to be used in a model, as opposed to what I wanted it for (just making notes).
Message 7 of 8
Scoox
I would like the ability to add notes to points and features in sketch and model environments, like I can add notes in Google Sheets. The note is shown on hover. Having to keep notes on a separate file with screenshots is how I do it at the moment but it is a huge waste of time.
Message 8 of 8
mbarbone
When I click these buttons, I get the following error:
