How do I make an appearance pattern go in the same direction?
Hi!
I have multiple faces, but for each face the pattern goes in different directions, how would I fix this?
Here's a pic for my problem:
keqingsong
Watch this video at 2:21: https://youtu.be/WX-RRZhDrOg?t=141
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
TrippyLighting
The full geometry of the object is hard to determine in the screenshot, but I am assuming all these faces belong to the same body. I would change the texture mapping from "automatic" to planar projection for the entire body.
This will require you to poco a direction and often picking the axis of an origin is enough. Otherwise make a 3D sketch with a single line and that line can hen be used to define the direction.
if you can share the model I can demonstrate this. (attach as .f3d and attach).
