How do I make a joint for this roller?
acondax
acondax
Hi there!
I'm a longtime Inventor user migrating over to Fusion360 for hobbyist 3D printing in my spare time. I'm trying to design a piece that slides across two copper rails using plastic rollers. Trying to understand the benefit of joints over Inventor's assembly constraints, how would I be able to create joint that allows the rollers to contact the rails and roll across them?
I've attached two images. The first shows a closeup of the black roller on the copper pipe. The copper pipe appears as a blue circle here because I've designed some plastic blue endcap. But you'll notice that the roller and pipe are not concentric. The second image is a wider example of the part being designed for context.
Any tips or explanations would be appreciated. Just so I can start wrapping my head around it.
jhackney1972
Joints are a challenge where you need a tangent contact.  In the one below, I placed the two components in the relative position, wheel on roller, and did an As-Built Joint.  The application create a slider joint for me.  Now to get the wheel to actually rotate as it moves, that will be a Motion Link between two joints, one is the slider joint just created but the other is a revolve joint I have not quite figured out yet.
Note: Next time you post a question, please attach your model so those that want to help do not have to create a model just to try an answer your question.  Using your model will be a lot more relevant to you than mine.  Mine is attached, for what good it does you.  Simply drag the wheel to get the motion or animate the Slider joint.
John Hackney, Retired
acondax
Thank you very much for the explanation and attaching the file. If I have any more questions in the future, I'll be sure to post a copy of my model. Thank you very much.
davebYYPCU
There is a plate with axles, (Rigid Group)
Revolve the wheels on the axles.
Slider is between the plate and the grounded rail cylinder.
Might help...
chrisplyler
The Pin-Slot joint type basically combines the functions of a slider and a revolve into a single joint. To create the rolling effect, you make a Motion Link (since the Pin-Slot joint is really two joints in one, you chose the "with same joint" option) that relates a given distance of slide with an appropriate angle of revolve. Once that is set up correctly, a wheel will roll along.
