how do I import a dxf file as per belwo when I have no upload button?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I odnt seem to be able to get the hang of this, but I can never find this magic upload button.   How do I get to the data panel?
SaeedHamza
I don't really understand what you want ...
Are you saying that the upload button in the data panel isn't there?
And inserting a dxf can be done from the Insert menu, so why would you need to upload it?
Regards
Saeed Hamza
daniel_lyall
That's a bit of a slight bit of bad wording.
  1. From the command ribbon in Model Workspace, select Insert DXF
It should be. From the insert menu on the command ribbon in the model work spaces select insert .dxf
or
From the command ribbon in the Model Workspace under insert select insert .dxf
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
