how do i fix oval holes after scaling?
nocturnalwelding
Message 1 of 18
nocturnalwelding
Hi, this is my first project and it's been fun hacking my way through it. I want to plasma cut this out. So this started as a svg. I had to scale non uniform to make it taller and my headlights turned into ovals. How can i make them circles again? Or delete and add circles? I've tried a couple crazy things, But then fusion crashed so i came here.  Also I would like to redo this project in the future and make it parametric.
How would i go about tracing it like a canvas so i can make it parametric in the future? thank you.
Replies (17)
Message 2 of 18
SwApNiLbAd
try to deselect the circle when you are scaling the full body.
Message 3 of 18
nocturnalwelding
Thanks for the help i'll try it out when i get home.  What would be the best way to trace it like a canvas? So i could make it parametric then enter it back in to my assembly.
Message 4 of 18
nocturnalwelding
Cant deselect cause I need the outside also.  What's the best plan of attack for tracing it?
Message 5 of 18
g-andresen
Load the image into Inkscape and scale it differently for both axes.
Then I would vectorize the image in Inkscape.
regards
günther
Message 6 of 18
Beyondforce
Hey @nocturnalwelding,
I hope this video will help you.
https://autode.sk/2W6VYID
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 7 of 18
SwApNiLbAd
Hi @nocturnalwelding i think you have to make circles as new component then you can deselect them when you are scaling.
Message 8 of 18
g-andresen
The original aspect ratio was changed when copying this picture.
Either you look for a new one or you use an app that corrects the aspect ratio.
 Günther
Message 9 of 18
etfrench
The easy way would be to scale your original drawing using the same value for X and Y.  Fill the unused area with a simple pattern.
ETFrench
Message 10 of 18
nocturnalwelding
Hey, everyone thanks for all the suggestions. Im super busy welding. I'll try your suggestions tonight. thanks again.
Message 11 of 18
nocturnalwelding
Ok round 1 Beyond force method. It's midnight and i finally get to play with fusion.  I deleted everything on the one side with the help of your vid and sketched out and pulled a new headlight.  Im no artist but wanted your guys feedback on how it turned out.  If it stil looks wierd i'll try the inkscape method. Since i have even less time in inkscape than i do in fusion it seems like it might be a harder route.
Message 12 of 18
Beyondforce
It looks good. But of course, it depends on how it fits with the original sketch?
In regards to the Inkscape solution, that might be a good idea as well. If you need some help with that, I have created a video that shows how to use Inkscape, check it out: https://youtu.be/9zp_iTzpxz8
Cheers / Ben.
Ben Korez
| YouTube
Message 13 of 18
etfrench
I think the oval side looks better Smiley Happy
ETFrench
Message 14 of 18
nocturnalwelding
thanks for your guys help really appreciate it, as i was going to give up on it.  gotta go to sleep. left off on fighting it to mirror. Smiley Happy
Message 15 of 18
nocturnalwelding
Just wanted to say thank you for everyones help. It was a fun 1st assembly.
Message 16 of 18
Beyondforce
@nocturnalwelding,
It looks great! Really good job 🙂
Cheers / Ben
Ben Korez
| YouTube
Message 17 of 18
nocturnalwelding
Thanks man, got done just in time to use it at king of the hammers!!
Message 18 of 18
Beyondforce
BTW, Have you seen my last video? https://youtu.be/VU9sB6rYrto
Ben Korez
| YouTube
