How do I export as STEP only selected
How do I export to a step file only the currently selected body? I'm doing variations of a basic form I want to bring back into SolidWorks, but don't want all the bodies I had imported into Fusion to work around.
Mark
JamieGilchrist
hi mark2t,
if you right click on the component name in the browser, you can export just the selected component. then select Step from the dialog box and the STEP file will be created localy.
hope this helps.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Thanks. That works if I turn the Body into a component first.
