How do I do an edge loop selection?
Message 1 of 10
Hi everybody. I'm trying to make a selection of all the edges that loops without selecting one by one. In Maya and 3dsmax it's very easy to do but I can't seem to figure this out on my own in Fusion360. Any insight will be helpful.
Here is what I'm talking about:
https://streamable.com/2kmzj
Replies (9)
Message 2 of 10
melvinbrian3d
is this what you re looking ??
MelvinBrian3D
Message 3 of 10
I'm talking about this feature:
Message 4 of 10
melvinbrian3d
ohh that's a Double clicking in the edge, but you have to be in the Sculpt mode
MelvinBrian3D
Message 5 of 10
Ok, thank you for the response. I did try it out in sculpting mode and it does work by double-clicking on it. Do you know if there is a way to do this while in sketch mode?
Message 6 of 10
melvinbrian3d
in the sketch i do not think that exist!, but if you have a solid body you can try this ...
https://forums.autodesk.com/t5/fusion-360-design-validate/edge-loop-selection/m-p/8057280/highlight/...
MelvinBrian3D
Message 7 of 10
jeff_strater
actually, you can double-click in sketch to select a loop of sketch curves.  It does not handle branching, but if there is a clear loop, you can do it:
Jeff Strater
Engineering Director
Message 8 of 10
melvinbrian3d
thanks!!
MelvinBrian3D
Message 9 of 10
mavigogun
This is a basic first test for determining if Fusion thinks your Guide Rail (for Lofting) is continuous/all the nodes are co-located- which isn't to say the curve won't be rejected, but at least it is a start.
Message 10 of 10
Ok great! Thank you. Do you know if there is a way to do this while modifying the sketches? For example, if I want to add fillet on a loop, I can't simply double-click and have to manually click one by one.
