How do I delete or re-arrange versions of a design?
lemelman
lemelman
I have a design that has been through a number of updates - it's now up to V32, but as a result of some unknown accidental error, V32 is 'screwed' so badly that it can't be rectified. I discovered that V30 is fine. I don't know where versions 31 and 32 came from and I don't want them, so how can I get rid of them? I'm fairly certain there's a way to promote an old version to make it the latest, but I can't find how to do it.
I can open V30 but the save option is greyed out, even if I make a slight change, instead I get a message saying there is a later version available.
Please help.
jhackney1972
You cannot delete old versions.  Take a look at the Screencast to see the process of making an older version the current version.
John Hackney, Retired
lemelman
Hi John,
Thank you, that worked fine.
Is my memory playing tricks? I feel certain that once-upon-a-time I saw something that mentioned clicking the version id in the data panel brought up a little window containing options, one of which was 'promote to current'. But then again, I'm getting old.
jhackney1972
Yes, your memory is correct.  That process and icons were removed a few updates ago.
lemelman
Why on earth did they remove that very useful facility?
