How do I create a solid body from a pipe created in sculpt mode?
itchytoes
itchytoes
Hi --
This should be obvious, but I cannot seem to do it.   After I create an open pipe from a sketch in sculpt mode, and I finish the form, I end up with an open body.  How do I close it up so that I have a solid pipe?
Betty
donsmac
Convert the T-spline pipe.
Switch to the Patch workspace and Patch the ends of the pipe object.
Then Stitch the end faces to the pipe.
You may have to reverse the surface normal of the pipe body.
