How do I convert a dimension parameter to a unit less value?
Message 1 of 9
I have a Body in a Fusion 360 design that has a 1mm length. I want to scale this using a dimension parameter, but the scale feature requires a unitless value.
How can I convert a mm, cm, etc dimension parameter into something the scale feature can use?
For example, change 20cm into 200?
Replies (8)
Message 2 of 9
hpekristiansen
Why would you scale by something that has a unit? -I do not think it makes sense to do such a thing.
If your parameter is:
length = 17 mm
and you want to scale by 17, you simply type this in scale factor field:
length/1 mm
Message 3 of 9
TheCADWhisperer
I suspect that this question will be best answered by seeing the actual file.
File>Export and then Attach your *.f3d file here.
Message 4 of 9
I want to do this because I’m using Insert Derive to create multiple instances of the same body but with each having a different length... it’s aluminium extrusion with a complicated profile that I don’t want to replicate multiple times in the main design.
My thinking is to create the profile as a separate design extruded to 1mm, Insert this into the main design, and use parameters to scale it to the correct length.
You’ve answered my question as I think this will work, so thanks! But is there an easier way to do this? I’ve noticed that the Insert Derive command has a parameter/ favourite checkbox in the dialog but can’t seem to work out how that work.
Message 5 of 9
ryderbrooks
Pythagoras would disagree..
sqrt(7"^2 + 8"^2) would be a useful quantity, no?
Message 6 of 9
karlbot2000
Very slightly more concise syntax:
myLength = 17mm
myLength/mm
returns a unitless 17
You can also convert to other measurements in the same action.
For example:
myLength/in
returns a unitless 0.669291 (17mm=0.669291in)
Message 7 of 9
woodman.dana
This is actually quite useful for scenarios like this:
Say you have a wall that is 11' long and you want to do a pattern to duplicate a wall stud ever 24" along the wall. You could have a formula like:
wall_length: 132"
stud_spacing: 24"
num_studs = floor(unitless(wall_length / stud_spacing))
Which would get you "5" that you could then use in a pattern.
Without something like unitless or making things like ceil/floor etc support units, you have to come up with much clunkier ways to do this afaik.
Message 8 of 9
alan.ferrell
This is what I came to find out.  Thanks for that easy fix.
Message 9 of 9
etfrench
You can directly change user parameters to any unit type as well as unitless.
ETFrench
