How do I combine surface and body?
O.Tan
Advisor Advisor
O.Tan
So how do you combine a surface to a body? Is it the patch tool? or what?
Here's an example of what I wanted to combine, the blue is the surface I want to combine to the body (grey)
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
innovatenate
Autodesk Support
Autodesk Support
If you thicken the surface first, you'll be able to combine it with the solid body. Can I ask what you are trying to accomplish by combining the surface and solid bodies?
I wondering if the replace face command may be a feature of interest for you.
I hope that helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
jeff_strater
If you are using a Direct Modeling design (not history-based), there is also the Boundary Fill command. This allows you to combine overlapping solid and surface bodies, and select areas to keep. I'm not sure if this applies in your case or not, but it is an interesting and useful command.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
O.Tan
Thanks for the suggestions, gave me a few ideas and turns out I need to use the patch tool to get it done. I never understood the reason for patch and now I get it.
Once I'm done I'll probably post up a picture of it 😄
And I'm purposely working in history mode as it helps me to back track the design process, as what I'm doing is converting a actual product into 3D for visualization and I guess to train my sculpt/patch skills.
Omar Tan
Malaysia
