how can i patch this correctly
nubrandao
nubrandao
Hi, i need to cover this holes, but instead of deleting the hole, how can  i patch it correctly?
in the picture the hole was covered in powershape. but i want to do it perfectly without powershape and use fusion.
HughesTooling
EDIT. You could do this by unstitching and untriming but I guess you want this patch just to cover the hole while create toolpaths?
3 of the surfaces are pretty simple using loft and patch.
The one that looks the easiest doesn't seem to want to work as a patch just selecting the edges?
So you need a sketch, see attached file.
Note this surface needs edge 2 set to tangent.
Mark Hughes
Owner, Hughes Tooling
nubrandao
you right, using loft i almost covered everthing without sketch, and patch in some situations
johnsonshiue
Hi! If it was a solid body, Delete could help restore the face easily. Please take a look at the attached file.
Many thanks!
Software Test Engineer
