I'm still learning Fusion and so far my designs are single bodies that will be either milled or 3D printed. The current project is one where I need to align a body that will be tangent to a cylinder (brass cylinder surrounding the threaded area). I'm working to design the component that screws into the threaded area. In order to draw that part I need the battery clip moved to the correct location in relation to the brass piece. That new body will be 3D printed and will hold the battery contact shown on the right. The idea is that the bent tabs on the contact need to be touching the brass sleeve so that it makes contact. As first start I drew a tangent plane off the cylinder then offset it 0.080" which is where the back of the contact body should be. So far that plan hasn't worked out very well. Even if I succeed in moving the back to the contact to the plane It still needs to be aligned with the axis of the cylinder. I've tried to use move on the body, but without success.
What is the best way to move the right part to be tangent to the cylinder so that the bent tabs make contact?
I'll upload the design but I can't figure out how to add it.
