Hi! everyone!
How can I model it elegantly instead of the laborious way I did it?
I have two splines converted into tubes, and I want to join them using U-shaped tubes spaced, for example, 50cm apart.
This can be done as I did, by creating copies, or by creating all the U-shaped tubes in the sketch.
The question is whether there's an elegant way to solve this using a pattern.
So that Fusion 360 calculates the correct lengths and I don't have to copy or sketch each U-shaped tube.
If there isn't a solution for splines(Not symmetrical), is there one for non-parallel lines?
