How can I find out what these red lines mean?
wcarlsonM2NUS
Message 1 of 8
wcarlsonM2NUS
I have a small hobby knife set. in a small case The case latch never worked and then the hinge failed. Thought I could 3D print a replacement and thought the design process would be a good learning experience in Fusion. The hinge was a bit tedious and I redid the sketch a couple of times. Also trying to separate the design into components may not have been done logically. Perhaps the hinge should have been a third component or perhaps the hinge parts should have been a part of the corresponding components.
At any rate when I extrude the hinge parts I get these red lines and I don't know what they mean nor how to get rid of them.
Thanks!
Replies (7)
Message 2 of 8
TimelesslyTiredYouth
Hi @wcarlsonM2NUS
the red lines show up where there is an adjacent profile that is not selected. The intention is to bring these to your attention in case you really meant to also select the adjacent profiles.
For this case, I have no idea why the red lines have popped up. I saw something similar lately in another thread and am questioning whether it is a bug.
What do the red lines mean? - Autodesk Community
I'm going to look at your file and compare it to another, but I could be wrong about the bug but even still if I see the same thing I'll call jeff.
Message 3 of 8
@jeff_strater
I believe this is a bug, for some user's since the November update with these red lines...
no issue as seen in screenshot above...
can you check if this is reproducable on your end?
For @wcarlsonM2NUS
Solved: Re: strange multiple selection with red outine - Autodesk Community
could help with what jhackney did...
Message 4 of 8
g-andresen
The red lines indicate adjacent profiles that are suitable for extrusion.
However, it is important to constrain the position of the sketch of the hinge profile in relation to the boxes using projections.
(view in My Videos)
günther
Note: I have not updated all the extrusions for the modified sketch.
Message 5 of 8
g-andresen
Here is another variant with associated extrusions.
(view in My Videos)
günther
Message 6 of 8
wcarlsonM2NUS
Thank you all for your responses. I was able to figure this out. Again, thanks!
Message 7 of 8
wcarlsonM2NUS
I would like to know how you were able to open and close the box.
Message 8 of 8
g-andresen
I added a revolute joint and edit its limits
günther
