How can I create this parametrically, possibly with mirroring?
I'm trying to create something similar to this lamp, which exemplifies my current need.
I'm not sure of a way to create something like this, while not having to manually change the size of each ring, or being able to change the number of rings parametrically.
Can someone point me in the right direction to learn how to do something like this?
Beyondforce
Hi @Anonymous,
Okay, this is one way of doing it.
Cheers / Ben
Check out my video channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Thanks for the help!  The revolve is a good idea.  However, it looks like you created all of the ring lines manually, so it wouldn't be possible to change the number of rings later.
Beyondforce
You could also, draw the outside path, create a profile on the tip of the line, then use the Pattern on path.
Ben Korez
| YouTube
I think I get what you're talking about.  I'll give that a shot and see if I can't get that to work.  Thanks!
michallach81
That's just one way, there could be many more.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
