How best to add these oil passages?
I've drawn a crankshaft and need to add oil passages between the main journals and the rod journals. For each oil passage exit point I've created a construction plane, then a sketch, then added a point at the location that the oil hole exits.
From there I'm not sure of the best way to make the passages. My first shot was to create a new 3-point plane using the two exit points and a random third one, then a sketch on that plane, then a line connecting the two points. Then I used the Pipe tool to create the passage and extended it using a 1.5 factor to get it to pass fully through the rod journal. Then translate that down a little so it fully punches through the main journal radius.
Before I do that all 8 more times, can anyone think of a better process?
