I'm trying to hollow out a portion of the underside of a guitar body but am not having any success. These are the steps I did to try and accomplish this.
- Opened a new sketch on the XZ plane.
- Create/Project to Surface the sketch profile (Body Cutouts Sketch) of the carve area required.
- Modify/Split Face top surface of body using projected profile.
- Use Offset to create an offset body from the new faces created on the body top.
- Extrude offset faces past bottom face of the body.
- . Combine/Cut new bodies from extruding with original body.
The problem starts at step 4. The new faces created from step 3 will not highlight so I can pick them. The whole body highlights instead. I can highlight the new faces however, when not performing any task. I was pretty sure that this is how I'd done this before but it's been quite some time since I used Fusion so I can't say for sure. I've attached screenshots but can provide the file if necessary.
Thanks Kindly.
