Message 1 of 8
I thought this feature was working as I had hoped it would. I was really excited to see how easy I could place a hole on the face of a part and have the design intent update as dimensions changed.
I was trying something with parameters tonight, and it looks like the way you can place a hole broke again? Have a look at the Screencast. If I create the extrusion using a centered rectangle, the hole placement doesn't update when the sketch dimesions are changed. If I create the same extrusion using the box command, the hole placement updates as the size of the box is changed.
Is this a regression or designed as intended?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
