Hole issues
Hole issues
Hole issues
When using the Hole tool with the distance function it would be very handy if the tool kept the distance from the first hole depth.
If I input a depth for the first hole and then would like to place a number of additional holes I always have to input each depth manually.
I have also found that when using the References function, if I manipulate the view then the References function does not work.
TrippyLighting
Please create a screencast and/or share your design.
I have attached a screen shot, it is a small issue but it does cause extra work.
The first holes depth was input manually, after that I would like to see the tool use that first depth as the default until it was manually changed.
daniel_lyall
If doing one hole at a time on a face it does not rember the depth just the size. If you places them on a sketch or sketch point one at a time or many it does.
chuck this in the idea station, it's a good one.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
