It seems the hole feature is currently very difficult/impossible to work with.
I wish to make two aligned holes in two separate bodies, with slightly different diameters. I cannot use one hole to reference the other one for some reason, the holes are on different bodies, but must be aligned.
Ideally I'd like to reference both holes to a sketch point, but that is impossible. However much I click on the "Select" button next to "References" it doesn't allow me to set anything, it simply deselects itself. The only way to actually set something is to move the blue dot in the center of the hole and only then I can reference to straight lines only. I can also "snap to a point", but that is not what I want, I need persistent references.
This means that on a parametric part when some major things change the holes won't be properly moved and the part will get messed up.
Is this normal? Why can't holes be referenced to another hole on a different body or a sketch?
SolidWorks has excellent hole aligning mechanism that is missing in Fusion 360, or I haven't understood how holes work in Fusion 360.
