Hi all,
I recreated a hinge, including the motion, as part of getting to know Fusion. I was very excited to get it to work. I grounded the main body of the hinge, so the other part would move with the eventual door. But I discovered, when I import the hinge in a "new design" and turn the whole hinge (180 degrees) upside down (making it from left turning, to right turning), the main body starts moving, instead of the other part. When I ground the main body, I loose all movement. I have no idea why this happens, or how to fix it. Is there someone who knows how to fix this?
You can see the hinge here and download it to test for yourself: https://a360.co/3T7stpC
EDIT: I just discovered that the hinge kinda works "upside down", when I use another joint to animate (changed names of joints to reflect this)! I also noticed I can't define Motion limits in this turned version.
Sincerely, Eelco.
(Apologies for the Dutch naming)
