Hide and Show toggle visibility
Good Afternoon,
I am a big fan of the many updates FUSION incorporates, especially involving the UI.  However, I would like to mention an issue with the most recent update.  The hide/show toggle for sketches, bodies, components, origins, etc... goes from a shade of grey, to a slightly different shade of grey (eyeball icon crossed out or not crossed out).  I've tried the different environment backgrounds to lessen the effect I'm seeing, but there isn't a discernible difference between the 2.  I would prefer to have a distinct identifier between having an item visible or hidden (bright light bulb, eye icons in 2 completely different colors, etc).
Please let me know if this can be adjusted, or if I should revert back to the previous UI (if that's even possible at this time).
Thank you for your time.
Best Regards,
Beerbatter
Observer
Observer
Agreed.  I much preferred the light bulb style we had before.  Bright yellow bulb=On, Grey Bulb=Off.  Please bring back the light bulb.  Not liking the grey eyeball at all.
Thanks.
Thank you dblandino291.  You summed up very nicely my thoughts on this.  I'm surprised at the lack of response to your post.  The lack of differentiation in the new visibility toggles jumped right out at me the first time I saw the new UI.  The human eye is greatly aided by clear contrasts and different colors.  Going from the previous easily distinguished toggles to something that requires constant double takes is a failure in the very basics of UI design.
carl.j.barker
You can search for the icons in the installation and paint them a different colour. But it would make sense if this was an option inside fusion.
I'm interested, where did you find the icons in the first place?
Hello Carl,
I agree with your comment.  This should be an option inside of FUSION.  Would you be able to provide information on how you were able to manipulate the colors?
Thank you in advance.
Dave Blandino
carl.j.barker
Dave Blandino
Find the icons in C:\Users\(your profile\AppData\Local\Autodesk\webdeploy\production\39ae3be83754e11319952e5fb0373ee11dd09c95\Neutron\UI\Base\Resources\Browser\Eye
Note the long GUID type folder name will change depending on Fusion version (Updates will make a new one).
Back them up and use a paint package to edit the originals, I used Affinity Photo, but any good one will do.
