Hidden in 3d not hidden in 2d
knndnnr
knndnnr
When model geometery is passed into a 2d drawing it displays hidden bodies/components too. Is there a way (there needs to be a way) to have things that are hidden in the 3d model remain hidden in the drawing.
krithika.sundararajan
Hi knndnnr,
The visibility of bodies/components in the model does not affect the drawing views.
Our current solution to this is to move the hidden bodies to new components and exclude them from drawing creation. You could check out the threads below that discuss the same:
http://forums.autodesk.com/t5/design-validate-document/drawing-details/m-p/6222138#M48657
http://forums.autodesk.com/t5/design-validate-document/drawings-hidden-bodies-showing-in-component-d...
Hopefully this will help achieve what you want to do. Please let us know if this does not work for you.
Krithika
