Help with toggling automatic dimensions
Hi all,
Not sure if you've encountered this issue or not and yes i've googled to see if there were a solution available,
but these dimensions come up literally every time I draw a line, circle, or any other preset geometry that isn't a spline.
Is there any way to turn this 'auto dimension' thing off?
Thanks in advance!
jeff_strater
The short answer, unfortunately, is no.  However, these dimensions should only appear if you are typing in values during geometry creation.  So, if I infer your request here, it would be:  Allow a setting where you can type in length/angle for lines, or diameter for circle, etc., but not create dimensions for those values.  Is that correct?  If so, I would suggest putting it on the Fusion 360 Idea Station, to see if others share your same request.
We do have a project in the backlog to not create 90 and 180 degree angle dimensions (those should be horizontal or vertical constraints), which will help a lot, IMO.
Personally, I tend not to often type in values unless I want to later change those value by editing the dimension.  Sometimes I will "eyeball" the geometry, or use grid snapping, then apply dimensions later.  But that's a personal style...
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
