Help with taking snapshots.
Hi there
Is there a way to take a good snapshot of the design without the rame being visible? Ony the body edges?
thanks
Francesco
rishivadher
Hi Francesco, you can do the printscreen our make a save
that does not help.
I need to take a snapshot without the varios splines. It is for product showcasing
rishivadher
You can hide the splines that are in the sketch, for better render you can use the Keyshot
http://youtu.be/uYvdr3Nsw54
I am going to check immediately the plug in, thanks.
Helmi74
In the display settings menu on the bottom switch to Raytracing. That should help.
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
This helps. thanks!
